Clevite Bearings : P or H series?
Old Apr 19, 2007 | 12:07 AM
xssive's Avatar
Default Clevite Bearings : P or H series?
What is the difference between the clevite p and h series bearings? I will be using htem with a new l92 crank.
Old Apr 19, 2007 | 12:18 AM
Ls2Sonoma's Avatar
i think its the H's that have a wider surface. they will not work on some aftermarket cranks since the fillet is larger
Old Apr 19, 2007 | 02:43 PM
xssive's Avatar
Anyone else?
Old Apr 19, 2007 | 02:51 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
From what I've learned from the pro's at SDPC that built my engine, the P series are used for stock displacement engines, and the H's are used on the bigger 4" stroke engines...
Old Apr 19, 2007 | 03:36 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
More specifically, the H bearings are for the aftermarket crankshafts and are slightly narrower than the P bearings. This is needed because of the way the aftermarket cranks are cut, the wider bearings will not seat down the same and will cause an oil hemorage (sp?) and subsequent loss of oil pressure.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Apr 19, 2007 | 04:13 PM
xssive's Avatar
I have seen people using the H series with stock crank builds. Is there any advantage to this? Anything to do with loading on the bearings? This is going to be a FI 750hp target build
Old Apr 19, 2007 | 05:36 PM
ChevyChad's Avatar
Thanks for clarifying that Matt
FWIW I'll probably be in that same range (>700rwhp) once I get the meth system operating on my car... The P bearings haven't had any problems so far with 630 rwhp tho...
