Help with a new setup!
Old Apr 19, 2007 | 11:25 AM
CMKworm's Avatar
Question Help with a new setup!
I'm torn between the ms3, ms4, tr trak cam, or am open to other suggesstions. Here is my current setup and I can change out whatever I need to. Opinions please!
Current Mods:
346 c.i. LS1 – Stock bottom end
Cylinder Head Specialties Stage 2 Heads – These are being re-done
(REV 2.02 intake, 1.57 exhaust valves, & custom competition dual valve springs)
Comp Cam .222/.222 (Dur.) .566/.566(Lift) 112 (LSA) – changing to whatever
Comp Cam 7.4 Chromeoly Pushrods
Rollmaster Dual Roll Timing Chain
Yella Terra 1.7 Roller Rockers
Hypertech 160' Thermostat
Taylor 10 m.m. Plug Wires
NGK TR6 Spark Plugs
Racetronix 42lb./hr. Fuel Injectors – changing to whatever
Walbro 255lr./hr. In-Tank Fuel Pump
LS1 Edit
Fast 90 & Nick Williams 90 TB
SLP Mass Air Flow Sensor
SLP Flo-Pac
Jet Hot Coated Headers
" " Y-Pipe
" " Exhaust
" " McCord Electric Race Ready Cut-Out
Stage IV Speed Inc. Max Evil A4 Transmission
TCI 3500 Stall Converter – changing to whatever
B&M Supercooler
3.73 GM Motive Gears
TA Performance Rear End Girdle
Additional upcoming mods are: Meziere electric water pump, ls7 lifters, ASP UD pulley, etc.
Old Apr 19, 2007 | 03:53 PM
CMKworm's Avatar
tttttt
Old Apr 19, 2007 | 09:23 PM
CMKworm's Avatar
anyone????
Old Apr 20, 2007 | 12:58 AM
red02Hawk's Avatar
2.02 intake valves huh. ms3 probably would fit ms4 probably wouldn't. piston to valve is close enough with stock valves with the ms4. flycut the pistons or get new pistons with valve reliefs to fit the ms4. also don't underestimate the ms3 it is still a pretty nasty cam
Old Apr 20, 2007 | 07:17 AM
CMKworm's Avatar
When the heads are redone should I make sure the valve size is stock? Then could I run the ms4?
Old Apr 20, 2007 | 09:00 AM
red02Hawk's Avatar
yes probably, but i would still recommend getting new pistons and getting the bigger valves. if your in it for this much $ so far whats another 600-800. new pistons, new rod bolts, and the motor will spin 7500 with no concerns.
