Fordged Bottom End Setup Help...
Old Jan 29, 2003 | 02:11 PM
annil8r's Avatar
Default Re: Fordged Bottom End Setup Help...
Well i got my block honed .005, felpro head gaskets, and my new pistons pressed on my rods, and my crank polished and this cost 567.00
I got ross pistons from alan at FMS they came with total seal rings for about 600.00
I used Katech rod bolts are arp head studs 328.00
I think this will be a strong bottom end, I have been told it will hold a 300 shot of n2o.
It only cost me right under 1500.00
Old Jan 30, 2003 | 12:36 AM
T/A Medic's Avatar
Default Fordged Bottom End Setup Help...
Im planning on doing fordge bottom end. I was hoping to use my block and crank. But put Good Rods/Pistons in it.
What would be required? New block? just hone this one out? resleve? bored out .010? What size Rods/Pistons... and will 2cc Valve Reliefs be enough u think? Trying to do this right but not expensive. IE no 382 stroker kits... i was hoping to stay around 4k or so.
I have a double roller TC, and Ported Oil Pump... will switch cams out.
Ordered Abs Spd stg2 5.7s milled .025
when I get the short block im going with a 230/232 .585/.585 112 +4 X-RE Lobe Cam
Thanks Jason.
