Number of teeth for Crank Position Sensor?
Old Apr 22, 2007 | 09:51 PM
bunker's Avatar
Default Number of teeth for Crank Position Sensor?
Anyone know how many teeth are needed on the LS1 for the CPS? Usually CPS have a reluctor wheel or sprocket with a certain number of teeth on it, just wondering since the LS1 has it mounted on the crankshaft inside the engine, if anyone is ever counted the number of teeth required for the LS1 CPS to work, I'm just working on something right now so I needed to know.
I saw LS1's use a 24X sensor while later LS2's use 58X, does that mean it one uses 24 teeth while the other 58? Most likely but wanted to confirm.
Thanks for any help
Old Apr 22, 2007 | 10:07 PM
Grimes's Avatar
yup the later reluctor wheels have 58 teeth
Old Apr 22, 2007 | 11:00 PM
bunker's Avatar
Awesome!
Now for cam sensor I think I just need like a flag system to tell cam/crank relation.
