Oil on spark plug??
Old Apr 23, 2007 | 02:49 PM
SSkillz's Avatar
Default Oil on spark plug??
Will car was making some noise nothing big but something to look in too. As I was looking around i saw some oil on the plug wire i took it off and clean it and went ahead a pulled the plug it came out with some oil on it. I know thats not right so what could that be showing a sign of?? Thanks
Old Apr 23, 2007 | 03:16 PM
Deerhunter-Z28's Avatar
washed that ring out probably, it's not "that" bad, losing a little compression. If you have the money to rebuild w/ forged internals now is probably not a bad time.
Old Apr 23, 2007 | 04:50 PM
SSkillz's Avatar
And if you dont have money? lol
Old Apr 23, 2007 | 05:01 PM
Quickin's Avatar
Do what I've been doing for about the last 6 months, burning more oil than normal.
You should check all your plugs, maybe its bad valve seals in your heads and you may only need your heads refreshed.
Old Apr 25, 2007 | 03:19 PM
SSkillz's Avatar
This sucks
