Mild Head/Cam setups?
Old Apr 26, 2007 | 04:26 PM
  #41
BriancWS6's Avatar
Originally Posted by crazy02ss
Also someone said that the afr's are a direct bolt on is this true?
Yes, they accept the stock rockers and you can use GM headbolts if you wish, just make sure you get new ones as they are a torque to yield design.
Old Apr 26, 2007 | 04:28 PM
  #42
BriancWS6's Avatar
Originally Posted by Hawk108
BriancWS6 I just want to let you know that I am very jealous of your setup.
Thanks for the props
Old Apr 26, 2007 | 04:43 PM
  #43
Pipelayaz's Avatar
Hey Brian you have an awsome setup bro... I've had a goal of 450RWHP and I have yet to really buy anything...is there anything you would have done differently with your setup? Do you think you'd loose any low end with a 90/90 setup installed? Your car sounds outstanding as well.
Old Apr 26, 2007 | 07:03 PM
  #44
Asmodeus's Avatar
Originally Posted by Speedmonster185
Ok, so no tranny rebuild. I'll say $2k for the rear end if I can find it for that. I'll install the converter myself, so that will stay at about $800 for that, plus maybe $500 for tires. So thats about $3300. That leaves me with $1700 for heads/cam. Looks like the TSP package to me...
Gaskets? Head bolts? Lifters? Oil Pump? Timing Chain? Labor for the heads/cam swap? Hardened pushrods?
Here's what I did:
patriot ported LS6 heads with dual springs - 1050
custom cam from TR - 400
ls7 lifters - 100
ported ls6 oil pump - 150
ls2 timing chain - 60
pushrods - 100
head gaskets - 60
professional products intake - 400
labor for swap and tune - 1200
fluids and filters - 100
spark plugs - 20
That totals just at about 3600. Things you will also need are a convertor, and tires. add about 1000 for that. Now it's about 4600. You should slide right in and run right along or possibly faster than your cam only friends and be much more streetable if you stay in the 228/232 range. A4's are easier on the stock rear, just save for whatever breaks next, trans or rear.
Old Apr 28, 2007 | 09:19 AM
  #45
Pipelayaz's Avatar
ttt for a reply
