383 build
Old Apr 29, 2007 | 12:04 AM
Disturbed Bird's Avatar
Default 383 build help
this summer im hoping to build a 383. what would be the best parts for a rotating assembly? and with the cam i have in my motor now(242/244-112 lsa) how much power do u think i will make with AFR 225 heads and everything in my sig. and i do want to keep near stock compression ratio.
Old Apr 29, 2007 | 02:48 AM
DONAIMIAN's Avatar
First, I cant make out your mods in your sig pic. Secondly, what are your goals, and how much do you have to spend on the shortblock.
Old Apr 29, 2007 | 10:54 AM
parts in my sig are ls6 block, equalizer v3.1, dimond pistons, ls6 heads, ported TB, ls6 intake, flp LT headers, tsp x pipes, 12 bolt moser with 4:10 gear, spec 3+, tnt f1 wet 150 shot, bmr adj. TQ arm, bmr LCA's, bmr weld in SFC, lid, thunder racing TB ends, pro 5.0 shifter with ws6store short stick, racetronix fuel system, msd 8.5 wires, nitto 555r DR, timing tuner.
well i didnt want to spend more than 3500 on parts for the stroker kit. right now im making 440 all motor and 600 with no2. and with that said i probly want to make around 550 or more all motor if thats posable. but i would also be putting AFR 225 heads and a 90/90 setup.
Old Apr 29, 2007 | 09:46 PM
anyone?
