valve springs for T2 cam
Old Apr 30, 2007 | 03:34 PM
01black's Avatar
Default valve springs for T2 cam
I have a T2 cam ready to go in and a set of 918 comp springs which i'm told withh work in the combo with stock rocker BUT, i see everyone running 921's or PRC springs with that cam...the car will also be getting a 150 shot on top of it and wanted to make sure i wont run into any problems with this set up? Comp lists the 918's as the ones to use but i was just curious to see what people are using...........
Old May 1, 2007 | 01:34 AM
Phil'sC5vette's Avatar
Ive seen guys using 918 with the T2. I would not.
If you are going to use 918 with your T2 and spray it with a 150 shot, I think saving $300 dollar now will cost you $9K later
Old May 1, 2007 | 09:47 AM
ls1amit's Avatar
tsp sells them with the 918's in there package. So who has had thier springs break on them? I plan on running 918's they are rated at over .600 lift which is safe enough for this cam.
Old May 1, 2007 | 11:03 AM
PREDATOR-Z's Avatar
918s will be fine if installed at recommended height. The use of titanium retainers a plus.
Old May 2, 2007 | 03:47 PM
GuitsBoy's Avatar
Do you have an aversion to the popular gold or platinum dual springs? Theyre pretty affordable and come with Ti retainers...
