Ls1 piston rings (file fit) Need HELP!!!!!
Old May 1, 2007 | 10:21 PM
1fastz's Avatar
Default Ls1 piston rings (file fit) Need HELP!!!!!
My buddy just got his 98 ls1 block back from the machine shop and they did a hone/hot tank job. The mechanic told him since he honed it, it expanded the cylinder wall slightly and that he should get file fit rings. I was just wondering, what size ring gaps should he be running?? Some guy with a similiar setup told us hes running .018 top and .022 on the second. What exactly should be the file gaps???
Old May 1, 2007 | 10:53 PM
1989GTA's Avatar
There should be instructions when you get the rings. I would follow there recomendation.
Old May 2, 2007 | 02:38 AM
pist0lpete's Avatar
Exactly what he said^ also, take into consideration if your friend is planning on using nitrous on the engine because in that case he should gap the rings wider.
Old May 2, 2007 | 09:16 AM
1fastz's Avatar
what are some nitrous gap specs then??? thanks again
