Motor started right up, running lean and misfire.
Old May 7, 2007 | 05:16 PM
Lurius's Avatar
Default Motor started right up, running lean and misfire.
The 408 started right up, but I am getting a few codes now after it has idled for a short while. I am getting p0171 and p0174(lean left and right banks) as well as multiple random misfires.
Any reasons for this? Any easy fixes like a bad ground or something? As for the lean, it may be that the 31lb injectors simply arent enough, even while idling. I planned on upgrading them before I got too heavy on the throttle, but I assumed they are enough to idle well enough.
I thank all help and ideas! Video coming later on, the ms3 sounds BADASS. Other specs are in the sig!
-Lurius
PS: Think its safe to drive around the block for a few minutes?
