DIY H/C install
Old May 8, 2007 | 10:51 PM
THE CHOP SHOP's Avatar
Snap on sells one and GM High Tech Performance did a build up of an LS1 and the tools required for a rebuild. If you do not want to buy the tool you can mark the bolts before the turn and just turn them the specified degrees. With the motor in the car the tool would be the best route.
Old May 8, 2007 | 10:52 PM
6']['9's Avatar
thanks you dont by anychance have a link for that GM hightech rebuild. i tried searching that site and didnt get much.
Old May 9, 2007 | 06:51 AM
cowboysfan's Avatar
I tq'd them a specified with tq wrench then marked a line halfway down the bolt head and used as a reference when tq degreed bolts. 10k plus with 11:3.1 comp still holding.
Old May 9, 2007 | 11:41 AM
BAD2000TA's Avatar
Ditto. It's not hard. Toughest one was the #8 cylinder because the A/C unit blocks most of the bolt. But, a good estimate and you'll be fine.
Also, be very careful when taking off the intake. The power brake booser vacuum hose is wrapped behind the oil pressure sending unit on the top part of the block by the firewall. A lot of people give a good "tug" to get the intake off and break the sending unit. It's only plastic on top. Be careful.
Also, make sure you clean the cylinder heads bolt holes really really good. Any fluid in there and you'll crack the cylinder block. Any dirt and you'll get a false torque read.
Just follow the install university steps and you'll do fine.
Old May 9, 2007 | 07:18 PM
6']['9's Avatar
Thanks i feel good about doing it now.
Old May 9, 2007 | 07:23 PM
Asmodeus's Avatar
hardened pushrods.
Old May 10, 2007 | 04:04 PM
GuitsBoy's Avatar
For years people have been drawing horizontal lines on the bolt heads in order to gauge the angle.
