View Poll Results: which Pushrod size with torquer v3
7.400 inches
68.42%
7.425 inches
26.32%
7.500 inches
5.26%
Voters: 19. You may not vote on this poll
torquer v3 people please!
Old May 7, 2007 | 11:42 PM
dub.ya.es.SICK's Avatar
Default torquer v3 people please!
ok well i have sewing machine noise, with my torquerv3 with 7.4's what is other tv3 people running size wise? tryed search didnt work for me...i know i klnow about PR checker cant order it online really and dont know where else to get one, but i can figure that out later when i go to buy some but are people running 7.4's 7.425's or 7.5's thanks!
Old May 8, 2007 | 12:56 AM
cmon :")
Old May 8, 2007 | 08:47 AM
Prin's Avatar
I am running the 7.4's and it really isn't that loud man...
Old May 8, 2007 | 08:57 AM
mine is a definite noticeable sound.. checked rocker bolts too.
Old May 8, 2007 | 09:05 AM
Fratsit's Avatar
I am running 7.4's and I can here it. I am going to hold out until I buy a set of heads (looking at TFS) and then measure and change accordingly.
Voted for 7.4's.
R/
Frat
Old May 8, 2007 | 09:26 AM
tjwong's Avatar
Its best to check the preload, depending on how much the heads were milled, and how thick the compressed head gasket. I have used 7.400, and 7.450 and once 7.500.
Old May 8, 2007 | 09:56 PM
02LS1z's Avatar
I am using the 7.4s with the t3. I am running the 243 heads and there is some noise.
Old May 9, 2007 | 10:16 AM
Irocss85's Avatar
if stock heads I say 7.425. thats just over stock length and will make up mostly for the small base circle the cam was ground on. (assuming here its ground on a smaller basecircle like most comp cams.)
Old May 9, 2007 | 11:42 PM
DRTY LS1's Avatar
I'm running 7.4's with stock heads and the V3 and there is a little noise but its not bad at all....
Old May 10, 2007 | 12:36 AM
pHEnomIC's Avatar
same here.
Old May 27, 2007 | 02:27 AM
i can hear with window up and definitley window down, should i put pistons at TDC to check the rocker arm bolt torque on all cylindrs? somebody with good knowlege chime in!
Old Jun 11, 2007 | 10:19 PM
MASICUR's Avatar
jon @texas speed told me today that 7.400 are fine..
Old Jun 12, 2007 | 01:44 AM
minytrker's Avatar
I have used 7.350 with that cam on a stock ls1.
Old Jun 12, 2007 | 11:34 AM
PierreLS1's Avatar
7.400 4 me
Old Jun 12, 2007 | 12:16 PM
m6speed's Avatar
7.400 are fine, but the only way to be completely sure is to use a pushrod length checker.
