Which aftermarket oil pump do i need?
Old May 9, 2007 | 03:40 PM
ls1chris's Avatar
Default Which aftermarket oil pump do i need?
looking to change my stock oil pump out to a better one after the cam install.i was looking at seen tsp sells some thats ported and non ported as wells as thunder racing .Also seen a mellings oil pump..So what would you guys recomend to upgrade to ..
Old May 9, 2007 | 03:45 PM
SSpdDmon's Avatar
Hell, I don't even know what I have. I think it was a new, ported stocker. Have to look at the previous owners receipt. All I know is oil pressure is pleantiful under WOT.
Old May 9, 2007 | 03:50 PM
Fibbado's Avatar
Ported LS6 oil pump, a couple of the sponsors have them. Melling oil pumps are good too, but I would say just go with a ported LS6 from thunderracing
Old May 9, 2007 | 03:53 PM
justin quick's Avatar
I have a ls6 oil pump n my 02 SS. it never drops below 40 psi at warm idle and has more than enough psi when cruiseing or wot. just go with a ls6 or ported ls6 not 2 expensive and will be plenty for ya.
Old May 9, 2007 | 09:03 PM
ls1chris's Avatar
thanks guys just got off the phone with tsp earlier and i should be gettin my ported ls6 oil pump friday .. thanks for the quick responses
