Lifter Failure
Old May 10, 2007 | 02:27 PM
TchargedLS1TA's Avatar
Default Lifter Failure
I dont know if any of the other shop have been having this problem, but we have been seeing alot of lifter failures after cam swaps. 3 of the last 5 cam swaps we did, we ended up having to pull the heads to replace lifters.
I talked to Jerry Cantrell at Schneider Cams and he's blaming this new EPA compliant oil. He told me it doesnt have zinc, phosphorus and other chemicals that help aid in high-pressure lubrication. Does this sound right ot anybody? Is something happening when the lifters are disturbed during a cam swap?
Old May 10, 2007 | 03:19 PM
8a8mfh's Avatar
Pull the heads to swap lifters---leads me to believe you're talking about LS1's which have roller lifters.
I have heard a lot in the past five years about the oil problem. It's usually flat tappet lifters that have problems, I have had a few new ones go bad with a new cam but not since using diesel oil like Rotella T and GM EOS.
Since there haven't been factory produced flat tappet engines coming out in around 20 years the EPA hasn't considered it much of a problem I guess.
Old May 11, 2007 | 12:28 PM
Patrick G's Avatar
LS1 Tech Administrator
Moved from Advanced Tech. More eyes in here.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old May 11, 2007 | 12:34 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
How exactly are they failing are you talking about collapsing lifters or the lifters not pumping up?
Old May 11, 2007 | 12:55 PM
PREDATOR-Z's Avatar
Well on high lift cams, the lifter tends to go down further into its bore, that could reduce its oiling capability.
also year and block design has a big influence on that.
Morel/Comp/cadillac did a study on that and created lifters that cater to this change.
I always recommend changing lifters on anything over 50k miles, the fact that heads need to come off is the main reason poeple shy away from it.
Old May 11, 2007 | 01:07 PM
The lifter collapses. We normally see it in the first 4 lifters on the driver's side for some reason. We always offer the option to go to the LS7 lifters, since they are better design and only $125
Old May 11, 2007 | 01:18 PM
LSWon00's Avatar
The new LS1 lifters from Crane Cams are designed to cure this. Check them out.
http://www.cranecams.com/?show=newProduct&id=13
Old May 11, 2007 | 01:33 PM
vettenuts's Avatar
As are Morel's.
