Help needed!!!
Old May 10, 2007 | 10:37 PM
Randy_S's Avatar
Default Help needed!!!
Ok, I have had my car for approx a month and a half since I have been home. It is burning about a quart of oil a week! I had it tuned by the original assembler and he said that it was probably just oil from inside the exhaust still from the old #7 piston that was bad. I now know that it cant be the case as I have long blown all of that out.
It smokes when I get on it hard or when I have the RPM's high then just let off the gas and leave it in gear.
I had the car retuned elsewhere and it quit smoking so bad but I am still not pleased. I put way to much money in the motor to have it smoke like some old beater!
I have disassembled the PCV valve and capped off the air tubes from the valve cover to the throttle body.
I also have a breather in the oil fill cap to release pressure.
