NEED HELP PLEASE!!!
Old Apr 26, 2003 | 03:45 AM
hugcam's Avatar
Default NEED HELP PLEASE!!!
I have started my cam install and I can't get the rear bolt for the passenger coil pack bracket off. <img src="https://ls1tech.com/threads/images/graemlins/confused.gif" alt="" /> Drivers side only took me 10 minutes. There is a wiring harness and two hoses, (I think they are A/C hoses) in the way of getting my socket on the bolt. Should I remove the hoses? There is practically no room back there, it is making me scared of trying the rest of the swap! HOW are you supposed to get a valve spring compressor back there. Please any info would greatly be apreciated since I know so many of you have done cam swaps yourselves. By the way it is a 99 Z if that helps. Thanks.
Old Apr 26, 2003 | 05:04 AM
SoCal LS1's's Avatar
Default Re: NEED HELP PLEASE!!!
Try using a deep socket, or you may have to use an open ended wrench and turn it a little at a time when putting it back together leave that one out, but make sure the others are tight for a good ground.
