Pushrod Length??
Old May 14, 2007 | 07:36 PM
jds99camaross's Avatar
Default Pushrod Length??
I need to know what size pushrod I need to use on my stock heads, with a comp cam .571 .573 lift 112 lobe sep. camshaft. I was going to use the stock length, but I hear different from other people. What length or brand should I use??
Old May 14, 2007 | 11:30 PM
85ta383's Avatar
spend $20 get a checker and dont guess.. will save you a few $100 in pushrods
Old May 14, 2007 | 11:37 PM
the_merv's Avatar
Veteran: Air Force
Did you do anything to the Heads, Head Gaskets, change the Deck Height?
Old May 15, 2007 | 12:05 AM
Blk97WS6's Avatar
as long as you didnt do anything with the heads, and change the deck hight, you should be fine with 7.400s. The only true way to know, is do what was already mentioned and get PR checker.
As far as the brand, just go with some hardened PR's from thunder racing, or texas-speed.
Old May 15, 2007 | 08:21 AM
I am limited on time! I am leaving next wednsday for basic training and won't be back until about jan. 08. even then I will only have a few weeks to get my **** together to move. So I went ahead and bought some 7.4's Thanx guys
Old May 15, 2007 | 09:11 AM
Blk97WS6's Avatar
as long as the heads havnt been touched, 7.400s should be ok.
