solid motor mounts
Old Apr 27, 2003 | 09:42 AM
BYBYC5's Avatar
*Bad Trader*
Default solid motor mounts
where can i get some or how to make em....
Old Apr 27, 2003 | 10:13 AM
Ryan K's Avatar
Pathological Modifier
Default Re: solid motor mounts
Honestly, have you considered a poly motor mount. I'll alawys recommend the poly over a solid. I installed poly on both sides and did not notice a great deal of vibration at all. I think that with a solid, you definately will.
JMHO...
Ryan K.
Old Apr 27, 2003 | 10:32 AM
ShiznityZ28's Avatar
I run the spohn solid mounts. i am taking them off to run a mad man motor plate. If you want to know were to get a set send me a email @ the.shiznit@verizon.net
Old Apr 27, 2003 | 10:33 AM
DERTY's Avatar
The Bull
You can get them from Spohn Performance or Madmand Racing. They would be a little tricky to make your first set because the angles and hole locations are a little different on each side. So there would be some trial and error getting that just right. Plus they are fairly inexpensive from both shops, so is making your own set worth the headache?
