Oil pressure to high?
Old May 25, 2007 | 02:31 AM
MS3Z's Avatar
Default Oil pressure to high?
I bought a used 2003 silverado with the 5.3. It has 39k miles on it. Well the oil pressure is saying it is way over 80 psi when accelerating, does this sound right?
Old May 25, 2007 | 02:32 AM
staringback05's Avatar
ever overfilled it?, check it with a manual gauge
Old May 25, 2007 | 03:06 AM
cowboysfan's Avatar
is engine warmed up at that psi?
Old May 25, 2007 | 03:36 AM
MS3Z's Avatar
Yes, I'm starting to think its the gauge because the gauge won't reset to 0 when I start the truck and it is really jerky as if its sticking.
Old May 25, 2007 | 09:28 PM
Black_98Z's Avatar
Might also be the oil pressure sending unit
Old May 25, 2007 | 11:28 PM
bczee's Avatar
could be the bypass valve in the pump is stuck.
Old May 26, 2007 | 08:32 AM
2 SSlow's Avatar
You need to put a manual gauge on it...that will tell you what's really going on.
