Heads and cam combo.
Old May 26, 2007 | 12:44 PM
caMnaro's Avatar
Default Heads and cam combo.
Is this a good setup that will make good power and still be somewhat drivable. What are some track times from people with a close setup. The car already has a ls6 intake, spec 3+ clutch, 3.73 gear, Mt Drag radial, Hooker long tubes, ORY, and magnaflow catback. I will be getting items listed below.
-Precison Race Componets stg. 2.5 5.3L heads.
-Texas speed magic stick 3
-Texas speed ported LS6 oil pump
-Gm Heads and cam gasket and bolt kit
-7.400" pushrods
-Gm ls2 timing chain
-Racetronix fuel pump and hot wire kit
-TSP 42# INJECTORS
-and will be dyno tuned after it is complete.
Old May 26, 2007 | 07:47 PM
Stangkilr's Avatar
I think you will be happy with that setup. I used to run a nice DD setup that put down good power and great times
TSP 231/237 cam
Patriot stage 2 5.3's
Fast 90/90 combo
+all the bolt-ons
447rwp/398tq
11.61@121.9mph on 17's full weight. That was through my corsa exhaust!
