Springs for X1 cam?
I just wanted to know what would be better to use. See i planned on using stock heads for a while and I know you have to do some work to fit double springs on stock heads unlike the 918's.
918's will work fine for that application with stock heads. I ran them VERY hard for 5000 miles with the F1 cam. (.591 lift) You may want to check spring pressure after 10000 miles or so, but they should be OK for about 15000 miles.
