Clearance issues
Old May 29, 2007 | 04:07 AM
derrickman05's Avatar
Default Clearance issues
if my heads are milled .018 and i have a cam that specs out at 235/240 600/609 will i run into clearance issues
Old May 29, 2007 | 07:04 AM
Viper's Avatar
Depends.
How far are your pistons out of the hole?
What head gasket are you using?
Do your pistons have flycuts in them?
Old May 29, 2007 | 08:42 AM
PREDATOR-Z's Avatar
What is the LSA/ICL of cam, What valves are you running
Need more info.
Old May 29, 2007 | 07:39 PM
stock everything(block valve dia push rod length ect.) 111 lsa stock LS6 valve
