quick cam question
Old Jun 1, 2007 | 07:32 PM
098z28's Avatar
Default quick cam question
hey guys i have a comp cam sitting here i can buy from a guy for really cheap its bran new but i cant find a rpm range on it or nothin i do have the part number and ive looked it up and got a link for the specs.. could someone please tell me what this cam is good for i.e. low end mid or high and also how much should it lope? and will i be able to use my stock springs? or maybe ls6 springs ive herd u can use sometimes and there really cheap compaired to others..? please let me know any info will be greatly appreciated
http://www.compcams.com/Technical/Se...er=54-412-1111
thanks guys
Old Jun 1, 2007 | 07:34 PM
098z28's Avatar
well for some reason my link isnt working so ill copy and past specs.. thanks
Camshaft Specification Table
Part Number 54-412-11
Engine 1997-Present General Motors
4.8ltr-6ltr
Gen III/LS1/LS2/LS6,
8cyl.
Grind Number LS1 XR265HR-14
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.522 0.529
Duration At 0.006 Tappet Lift 265 271
Valve Timing At 0.006
Open Close
Intake 21 64
Exhaust 72 19
These Specs Are For The Cam Installed At 112 Intake CL
Intake Exhaust
Duration At 0.05 212 218
Lobe Lift 0.307 0.311
Lobe Separation 114
Recommended Valve Springs 941-16
Old Jun 3, 2007 | 10:57 AM
098z28's Avatar
anyone help??????????
Old Jun 3, 2007 | 08:37 PM
ls1 1990 VN's Avatar
It's a baby cam, standed lope
Old Jun 3, 2007 | 11:06 PM
Hawk#153's Avatar
its a small cam with a more agressive sound than stock. i would never trust stock springs with any cam swap ,and it should pull up to around 6800 with more mid range...thats my guess
Old Jun 4, 2007 | 11:25 AM
098z28's Avatar
so do you guys think its worth me wasteing me time installing it for the summer? 'my motors comeing out this fall' and like i said i can get it really cheap like 100 or 150.. thanks
Old Jun 5, 2007 | 02:31 AM
Depends on what your after,but really if your gonna go to the trouble of a cam swap put in a decent one. My 02
