Cam Q's
Old May 1, 2003 | 08:20 AM
1MEANSS's Avatar
Default Cam Q's
Two weeks from now I will be bringing my car in to get a custom comp cam 224/228 .581/.581 114lsa, they said this cam will work great on and off the n20, just wondering if I made the right decision...
Old May 1, 2003 | 11:36 AM
Cal's Avatar
Cal
Default Re: Cam Q's
You do realize with that kind of lift you will need some good springs, probably dual coils would be best; and you will need to replace the springs once a year. Plus you will have a lot of valve train noise. I would personally go with a little lower lift, but it's your call.
Old May 1, 2003 | 12:16 PM
DONAIMIAN's Avatar
Default Re: Cam Q's
I agree. If your running stock heads .550 would be good, but if you want to upgrade to better heads later, I would say around .560-.575 lift. Just my 2 cents
Old May 1, 2003 | 12:32 PM
1MEANSS's Avatar
Default Re: Cam Q's
I do realize that, also I was told that it would work out the best with the n20, I'm getting comp ovate wire springs,comp 7.400' chrome moly pushrods, crank bolt and sensor,dyno tuned gears,injectors,t-stat,cam, and I will also be putting on true duels!!!!
Old May 1, 2003 | 12:57 PM
1MEANSS's Avatar
Default Re: Cam Q's
Do you guy's think this cam will make good power throughout the powerband????
Old May 1, 2003 | 02:35 PM
42NightZ28's Avatar
Default Re: Cam Q's
I would like info about this also, it would seem you'd have to rev the snot out of the motor to get into the power band.
Old May 1, 2003 | 03:21 PM
1MEANSS's Avatar
Default Re: Cam Q's
???What, I was told that this would be the best to go with sense I'm spraying, my buddy just put in the 224/224 .581/.581 and he's making great power with that cam, I on the other hand went with the split dur. 224/228 just because they said it would work better with the N2o, did I make the wrong choice??????
