Crank Bolt for UD PUlley
Old May 1, 2003 | 02:04 PM
Ramair346's Avatar
Default Crank Bolt for UD PUlley
I received my UD crank pulley and didn't recall seeing a new crank bolt. Can I just go to the dealer and get another stock bolt? Will that work? Or do I need to get a longer bolt?
Old May 1, 2003 | 02:58 PM
Richie Carbone's Avatar
BADA BING BADA BOOM!!!!!!
Default Re: Crank Bolt for UD PUlley
Just go down to your local dealer and pick one up, they are around $6.00
The bolt that is included with the pulley is a factory bolt anyway.
horist's Avatar
New stock bolt will work fine, you can use a longer but I don't think it's really necessary (had no probs putting mine on or taking off w/stock length bolt)
GM Part# is 12557840
Old May 1, 2003 | 03:00 PM
horist's Avatar
Looks like closest dealership to you that has one in stock is
BOSTICK GMC TRUCK CENTER
PONTIAC, MI
but you can order from any dealership if you don't want to drive out and pick one up
(I used partsvoice.com to find where they're in stock)
Old May 1, 2003 | 03:02 PM
Ramair346's Avatar
Thanks for the input guys. I found one right down the street at the Chevy dealer. $3.34
