General cam knowledge needed....
Example...ISKY LSX CAM 232/242,.530/.540 ON A 113LSA. pOWER BAND IS ADVERTISED AS 2500-6800 RPM.
VS.
TORQUER V.3 231/234 .643"/.598" 111 LSA...LETS SAY THE TOR V.3 WAS ON A 113LSA. POWER BAND IS ADVERTISED AS 2300-6700 RPM.
WILL PEAK HP/TQ NUMBERS BE AT DIFFERENT RPM'S? IF SO, WHICH ONE WOULD HAVE THE HIGHER/LOWER PEAK HP/TQ NUMBERS BETWEEN THE TWO CAMS?
