Rocker Question
Old Jun 4, 2007 | 12:11 AM
Hawk#153's Avatar
Default Rocker Question
Been hearing some noise from valve train like a slight chatter, took rockers out and they had some uneven wear. it seems that the needle bearings were worn because not only do the rockers move from front to back they also tilt from side to side and when i did that they made a clicking noise. and yes they were all on there tight when i took them off..do you think that is what i was hearing?? and if so what would would cause it??
ps ..my cam specs are 605/612 237/242 112lsa
manley chromoly stock length 7.4 pushrods
patriot performance dual spring kit
Old Jun 4, 2007 | 05:10 AM
vettenuts's Avatar
They have been known to dump bearings, can you see the needles and count them? The ones that are noisy, see if they have less needles in them than the others.
