CAM ?
WANT TO KNOW EVERYONE'S THOUGHT ON CAM, SPRING, ROCKER, AND PUSHROD SWAP OUT. WHO HAS THE BEST SET UP FOR STOCK HEADS AND BLOCK AND WANT MORE OF A LOW AND MID RANGE POWER ADVANCE. AND WOULD LIKE A GOOD LOPE TO IT. AND ONCE I CHANGE ALL THIS OUT IT SHOULD TAKE MOST OF THE MOTOR NOISE OUT ON START UP RIGHT.
You wont need to change the rockers. How far are you willing to go with this cam, is it your daily driver. Are you willing to get gears, or stay with what you have. Whats your HP/e.t. goal. Do you have an A4 or M6. Does idle quality matter.
