6.0 headgasket?
Joe
Joe
Joe
Joe
.Joe
Joe
Joe
In general you want to choose a gasket only about .030 more than bore, but unless you're boosted I do not see any issues here.
Now that you mention that about the quench area though- I have my boosted LS2 that I ordered the Fel Pro MLS gaskets for (heard a lot of good about them, so I'll give them a shot) and they are a 4.100 bore. Do you think I'll run into problems using them?? Those are the ones I was told to use and I don't believe Fel Pro makes any others too, but I believe they are under 4". Will this cause problems
?? Thanks for your help.Joe
Head and block prep was meticulous.
It isn't too bad yet, I just crack the radiator cap before I take the car out for the day to make sure there is no residual pressure from the day before. It's not like it pushes a quart in one pass or anything, so I'm in no big rush to do it. Just wanted to make sure those Fel Pros will work. Let me know if you think I'll have a problem or not. Thanks!
Edit- I should add- the 20-21 psi thing is for race days and special occasions only, not daily.
Joe
