HELP! Car is missing at idle and I changed plugs...
Old Jun 7, 2007 | 06:43 PM
SlowazzVette2's Avatar
Default HELP! Car is missing at idle and I changed plugs...
What could I have over looked? I changed plugs and wires and now I get a multiple misfire code. Thank you.
Old Jun 7, 2007 | 10:58 PM
ArcticZ28's Avatar
Was this happening before the plug/wire change? If so, have you checked your pushrods/springs?
If it wasn't doing it before, just go over the boots and make sure each one double clicks to the coil pack and clicks firmly onto the plug.
Old Jun 8, 2007 | 09:02 AM
GuitsBoy's Avatar
Im with arctic on this one. Plus wires arent seated correctly. Make sure you get 2 clicks on the coil side. Wires are a huge pain in the ***.
Old Jun 8, 2007 | 09:09 AM
tylerdj's Avatar
Yep, you probably didn't seat a boot fully on the coil or the plug.
Old Jun 8, 2007 | 09:21 AM
Cool thanks i will try that. It was after by the way.
