Torquer V.2 question
Old Jun 10, 2007 | 06:09 PM
delsold's Avatar
Default Torquer V.2 question
this may have been asked before, but everytime i search its bringing me to google. I'm going to order a TSP camshaft package, and i'm kind of concerned about the 918 package they have. They 918's say they can support .600" of lift, and the v.2 is like .595"/.598" i believe. Is this pushing the 918's? I could get the PRC dual spring kit, but its an extra 120 bucks which i was going to use to buy a timing set. Will the 918's work safely, and reliably with a v.2?
Old Jun 10, 2007 | 06:47 PM
RedDemonLsX's Avatar
Get the PRC dual springs,its definitly worth the extra 120 bucks.Also there have been horror stories about the 918 breaking and you dont want that.As far as a timing set,just get the LS2 chain...its all you really need and its cheap.
Old Jun 10, 2007 | 07:58 PM
delsold's Avatar
thanks, i actually just read a thread that was up on the top of this forum about the breaking 918's. I thought comp springs were a quality spring....until they figure out the problem, and correct it, they lost one customer. Looks like ill be getting PRC duals for my v.2 swap.
Old Jun 11, 2007 | 09:27 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Definately look to the double spring setup. I've seen many 918 t2 cars work very well, but the double spring will give you a much longer life!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
