How to check for bent valves???
Old May 4, 2003 | 11:44 AM
Krazy98Z28's Avatar
Default How to check for bent valves???
I plan on pulling my passenger side head off today, whats the best way to check for a bent valve??
Also i'll be checking my lifters on that side also, how do you check for a collasped lifter.
Marco
Old May 4, 2003 | 04:46 PM
Camaroholic's Avatar
Default Re: How to check for bent valves???
If the head is already off, pull the valve out and roll it on a very flat surface (like a mirror or glass plane). If it wobbles, it's bent.
Another way (if head is on motor) is via a compression or leakdown test.
Or, if the valve is sitting .1" lower than the others around it (like on my '94), it's pretty obvious.
-Andrew
Old May 4, 2003 | 05:21 PM
wrencher's Avatar
wrencher
If you got the head off you can see if the combustion chamber will hold a fluid. The lifter is a little more difficult.., you can push down on all of them with a push rod , they all should have a little spring back to them. But if they bled down this wont work . If you suspect a problem what's 200 for a set?
Old May 4, 2003 | 07:16 PM
Krazy98Z28's Avatar
So much for taking the head off today. I couldnt get the freakin header off the ORP. I got all the nuts off of the studs. I was hoping i could pull the head right off with the headers hanging there but the stupid header wont let the heads come up all the way. I tried pulling the ORP but it just wanted no part of me. I guess maybe i should heat the pipe up and see if i can turn it.
