Hone with torque plates
Old Jun 13, 2007 | 09:38 PM
yobabiesdaddy2001's Avatar
Default Hone with torque plates
Do I need to have my block honed with torque plates for a 3.905 bore?
What is the beneifit and is it nessacary?
Old Jun 13, 2007 | 10:31 PM
LS1Formulation's Avatar
Having torque plates installed mimics the stresses the block would actually have with the heads bolted on, therefore making the bore that much more concentric when assembled.
Old Jun 14, 2007 | 12:25 AM
Jason99T/A's Avatar
I can shift faster than you.
The GEN III blocks distort a good bit in the upper portion on the cylinder bores with torque plates attached. I would highly recommend you use them when honing the block.
Jason
Old Jun 14, 2007 | 04:15 AM
welll honing with torque plates is what I will do.
Old Jun 14, 2007 | 02:12 PM
ls1 1990 VN's Avatar
I'm up for a new block as mine was done without and now apparently has two oval bores
Old Jun 14, 2007 | 02:55 PM
99 Black Bird T/A's Avatar
I'd insist on having it done with torque plates. Best to do it right the first time as others have said.
