Dropping oil pan #$@#$
Old Jun 18, 2007 | 10:35 PM
05 GSXR 1XXX's Avatar
Default Dropping oil pan #$@#$
so i thought i was going to drop the oil pan down this afternoon and tap it for my oil lines... well
whats the fastest way to get the pan off, i think unbolting the motor mounts then jackin up the motor would do the trick, but were talking 4-5 inches of clearence..
any advice would help!
Old Jun 19, 2007 | 01:25 AM
Doc's Avatar
Doc
Unbolting the motor mounts and jacking the car up is not going to be a big problem. Getting the bolts back in is going to be more of a issue.
Old Jun 19, 2007 | 02:45 AM
Krab's Avatar
I really doubt you'll have enough clearance to drop the pan by just unbolting the motor mounts and jacking up the engine/tranny. You'll hit the floorboard and only have a few inches of clearance between the oil pan and K-member. You have to lower the K-member a bit in order to have enough clearance to drop the pan. Good luck, it's no picnic.
Old Jun 19, 2007 | 02:47 AM
JMBLOWNWS6's Avatar
I doing it tomorrow It sucks to do I can tell you that much.
Old Jun 19, 2007 | 06:32 AM
King James's Avatar
There has been some better instructions posted before but the gist of it is....
Remove A/C
Remove alternator
Unbolt motor mounts
Unbolt steering shaft
Support motor from top
Drop k-member
Old Jun 19, 2007 | 08:10 AM
SMOKY's Avatar
Tenured Member
^ thats the only way ive been able to remove a pan. It sucks.
Old Jun 19, 2007 | 09:47 AM
Remove A/C
Remove alternator
Unbolt motor mounts
Drop k-member
ive done all those except drop the k member..
i noticed the gasket on the pan is metal looking, i thought all the oil pans had just rtv on them??
Old Jun 19, 2007 | 10:09 AM
juiSSed1172's Avatar
I dropped the k member when I swapped my oil pan. (previous owner stripped drain plug threads)
Old Jun 19, 2007 | 10:51 AM
Hennytime's Avatar
read the first sticky
https://ls1tech.com/forums/generation-iii-internal-engine/675343-rod-bolt-install-write-up.html
Old Jun 19, 2007 | 11:49 AM
King James's Avatar
LS1's have metal gaskets and yes you can reuse it. It is recommended to put a dab of RTV at the corners where the front cover and oil pan meet.
