Rod Length?
Old May 7, 2003 | 10:10 PM
Bink's Avatar
Default Rod Length?
Is stock LSX rod length 6.125" or 6.000" ?? Thanks for helping me out.
Joel
Old May 8, 2003 | 12:05 PM
Nasty N8's Avatar
Default Re: Rod Length?
6.100 is stock rod length.
Old May 8, 2003 | 12:33 PM
Bink's Avatar
Thanks Nasty N8! So I didn't have it right at all.
Old May 8, 2003 | 06:39 PM
Visceral's Avatar
wellllllll.... its 6.098". Problem is that the pistons are already out of the hole .010 in the stock setup. Another few thou may not be the brightest idea.
chris
Old May 8, 2003 | 08:11 PM
Bink's Avatar
the pistons are already out of the hole .010 in the stock setup now I'm really confused.. I thought it was .008" out of the hole.
Old May 9, 2003 | 07:40 AM
99 1LE SS's Avatar
You can go with a longer rod but you need to have the correct pistion for the rod lenght. I am using a 6.200" rod but i have to get a custom set of pistons made for the rod. With a longer rod you need to move the wrist pin higher on the piston to compansate for the increased lenght, but you will increase you dwell(time that the piston is at TDC) which will increase performance. I think i have that right.
Old May 9, 2003 | 09:53 AM
Nasty N8's Avatar
Yes you have that right. I use 6.200 rods on most of the motors we build. Helps out with a lot of things, like piston cylinder sidewall wear.
Nate
