Bent push rod
Old Jun 25, 2007 | 04:26 PM
ssfugazi's Avatar
Default Bent push rod
Acouple of months ago I went to the track, and on the last run I bent a push rod. I drove home very carefully, took the vavle cover off and found the problem. A rocker arm throw its bearings and bent that push rod. So I replaced them both and put everything back together. The car started up and everything sounded good. The car drove great. Well I went to the track again this weekend and bent the same push rod. The rocker arm was good this time. Does it sound like I have a bad lifter?
Old Jun 25, 2007 | 04:34 PM
melchoir's Avatar
Stop over revving or maybe upgrade valve springs? You're probably getting valve float.
Old Jun 25, 2007 | 04:56 PM
bczee's Avatar
+1 on that.. Change all of the PR, springs with some HD ones and check all of the rockers...
