will it need fly cutting
Old Jun 27, 2007 | 12:03 PM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
Default will it need fly cutting
234/240 .627 .641 112 lsa would that cam spec require fly cutting with a set of stock heads thanx
Old Jun 27, 2007 | 12:04 PM
MDoe8's Avatar
With a set of stock heads, you shold be fine with that duration. I'm on the stock heads with my 242/242 .595/.617 112
I'm no expert though
Old Jun 27, 2007 | 12:57 PM
LS1Tech Sponsor
thanx. anyone else? looking to buy this cam need to know.
Old Jun 27, 2007 | 01:14 PM
fbodyforever's Avatar
i was told by vengeance racing that on an otherwise stock motor their vindicator cam only had .030 PTV clearance on the intake valve, and that was at .604 lift. in my opinion even .030 was way to close. any more lift than that is way to much without flycutting.
Wayne
Old Jun 27, 2007 | 01:16 PM
Eric @ WAR's Avatar
Initially it seems like you'll be OK with the stock heads...however it's awfully close.
Old Jun 27, 2007 | 01:18 PM
LS1Tech Sponsor
well what ive understood before lift doesnt effect your ptv but duration does. but i could be wrong.
Old Jun 27, 2007 | 03:08 PM
both affect PTV clearance. when in doubt, build the motor and clay it. if it's too close, time to flycut. .100 is nice, but i personally wouldn't go less than .80. everybody has a different answer, it's all up to you how close you consider too close.
Wayne
Old Jun 27, 2007 | 03:33 PM
LS1Tech Sponsor
well this is going into my bolt on motor and i dont want to buy it if it wont fit
Old Jun 27, 2007 | 04:31 PM
chuckyt1's Avatar
I would think that duration on a 112 would fit. It is however, a big cam. No way I would run it without checking PTV first. Then you have to decide what you are comfortable with.
Old Jun 27, 2007 | 04:52 PM
LS1Tech Sponsor
well the reason i ask is because i dont have the cam and i dont wanna buy it if it wont fit ive seen people fitting slightly bigger cams with not as much lift
Old Jun 28, 2007 | 07:28 AM
PREDATOR-Z's Avatar
Correct at those durations.
Wayne
Not at these durations. The lift that affects PTV is not .050 lift but what is called "Tappet Lift" and those are two different things. Poeple in general confuse those.
Wayne
.030 clearance is insane and only a Lunatic would run that on any "Street" setup.
.080/.100 (int/exht) are the accepted "safe" norms and that is not even on a hydraulic setup.
