Little help.
Old Jun 28, 2007 | 07:13 PM
Justin Gibbons's Avatar
Default Little help.
Just installed a new cam, lifters, rods, locks, and 918 springs. All componets are comp, but i'm getting alot of noise in the valvetrain, ticking,and chatering..kind of sounds like a sewing machine. Is this normal?
Old Jun 28, 2007 | 08:10 PM
NviouSS's Avatar
need more info. specs of the cam and lenth of the pushrods?
Old Jun 28, 2007 | 08:20 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
It could be normal. One guy around here put a cam in his GTO and thought it was making a ton of valve train noise. We weren't sure if the preload was off or not. It still put down strong numbers and ended up when he got the installation numbers back everything was fine.
Old Jun 28, 2007 | 09:45 PM
cam specs are;
Duration @ .050 212/218
Gross valve lift .522/.529
lope seperation 114.0
Cam is a comp XR265HR-14
Push rods are 7.4"
Old Jun 29, 2007 | 08:12 AM
GuitsBoy's Avatar
Whats teh base circle? If its 1.450 a lot of people have had luck running 7.425 pushrods over th eusual 7.400. Anyway, some increased valvetrain noise is to be expected. The sewing machine noise is heard more often than not. Its worse with dual springs.
Old Jun 29, 2007 | 09:03 AM
....So is this noise from my springs or is there something wrong with my engine...
