What Heads to pair this Katech Cam with ??
Old Jun 29, 2007 | 03:43 AM
SS DNA's Avatar
Question What Heads to pair this Katech Cam with ??
I found this Katech cam and by the looks of the spec, 229 / 229 @ .050, .576 / .576 lift, 116 LSA, It looks like a strong cam with a sleeper lope.
What do you guys think should be a good match for this cam ?
I know it depends on my budget and all but I want to get an idea of what power I should expect with different head combinations.
Also, I think this cam will be a sleeper but can someone who has knowledge of cams tell me how it will sound just by reading the specs ?
Thanks to everyone
Old Jun 29, 2007 | 05:40 AM
PREDATOR-Z's Avatar
That cam has -3* overlap so it should sound close to a TR224 114 LSA (for reference since that cam has plenty sound clips)
It is on relatively soft lopes, friendly on spring. It should also have some decent trq output.
Old Jun 29, 2007 | 06:00 AM
slow trap's Avatar
a small runner head like the afr 205 should work great with that cam.
Old Jun 29, 2007 | 08:09 AM
Mac 2002 SS's Avatar
TEA's stage 1.5 5.3L or PRC's 2.5 5.3 L Heads should work just fine with that camshaft. Good luck
Old Jun 29, 2007 | 11:38 AM
SS DNA's Avatar
Cool
I originally wanted to get AFR heads to pair this cam with but of course you know, I have cheap thoughts in my head of some PRC heads and save some money.
Should I be in the 430 rwhp with heads and this cam ? and of course all bolt ons, or should I expect higher ???
And PEDATOR-Z, How can I find the overlap of a cam ???? The more its close to a positive number the less chop right ?
Old Jun 29, 2007 | 12:26 PM
slow trap's Avatar
it just so happens that i have a good set of tea stage 1 heads i'd let go cheap if you're interested. that cam has fairly easy lobes so i don't know about 430 but maybe 410- 420 should be possible.i made 436 rw with those heads and a 228r but i also had a fast 90/90.
Old Jun 30, 2007 | 07:47 AM
PREDATOR-Z's Avatar
Positive overlap more lope chop, negative overlap less chop and more stealth.
Old Jun 30, 2007 | 02:32 PM
SS DNA's Avatar
Cool
mmm Got it
