how does the TR 220-112 and TR224-112 compare?
Old Jun 29, 2007 | 07:46 PM
cals400ex's Avatar
Default how does the TR 220-112 and TR224-112 compare?
I was just curious how these two cams compare? How much higher will the 224 need to be revved? Will the 220 have a nice lope or will it sound stock?
Old Jun 30, 2007 | 03:34 PM
offaxis's Avatar
HEy
I have run both of these cams in the past. The 220/220 peaked about 6000 and the 224/224 peaked about 6300. There is about a 7-10 hp difference in the cams. The 220/220 with sound pretty stock on a 114 if thats what you are looking for. On the 112 it will have a slight lope. With both cams i ran well into the 11`s . IMO The 224 cam is still one of the best all around cams out there. if you want stealth go with the 220/220.
Hope that helps
Old Jun 30, 2007 | 06:48 PM
cals400ex's Avatar
how much better did the 220 do at lower rpms? i am looking to have a slight lope so i will go wtih the LSA 112.
Old Jun 30, 2007 | 07:49 PM
bigdsz's Avatar
The TR 224 is the best cam I ever had, lots of low end.
Old Jun 30, 2007 | 07:52 PM
offaxis's Avatar
Old Jul 1, 2007 | 02:31 PM
35th SS's Avatar
I could also say that.and its still there.
