H/C/I Question
Just give TSP a call for pushrod length...More than likely it will be stock length(7.400) or a little shorter with a 7.375 rod...Either way make sure...Ideally you should use a pushrod measuring tool once everythin is bolted on...Then go from there...You should like the head and cam package...These heads put up damn good numbers for the price...
Kev
I think for now, when i get the car im gonna do a true dual setup from TSP with some Longtubes, 4.10 gear, and suspension and throw my nitrous kit on at 125 wet and have some fun like that.... should be enough to keep my happy for a little while but im ALWAYS looking at new info etc. Ive been told a factory ls1 car can dyno around 300whp bone stock... is that true?
Kev
