Low Oil Pressure at Idle
Old Aug 17, 2008 | 02:49 PM
  #81
Ed Blown Vert's Avatar
I don't think its the plate. The gasket looks good. But its flush with the plate.
I am running out of ideas.
Attached Thumbnails Low Oil Pressure at Idle-cam-retainer.jpg   Low Oil Pressure at Idle-cam.jpg
Old Aug 17, 2008 | 04:37 PM
  #82
98Camarod's Avatar
It's not supposed to be flush with the plate. That would create no seal.
Old Aug 17, 2008 | 04:47 PM
  #83
I looked closer. Its sticks out just a bit.
Old Aug 17, 2008 | 04:54 PM
  #84
98Camarod's Avatar
Did it just start out of no where or it's happened since the new motor was built?
Old Aug 17, 2008 | 05:06 PM
  #85
Engine has under 50 miles. Pressure was fine when I installed it.
All I remember is one WOT run, then the pressure started dropping.
Old Aug 17, 2008 | 06:53 PM
  #86
All back together.
Cold 20#. Hot 10# at idle.
Old Aug 17, 2008 | 07:11 PM
  #87
98Camarod's Avatar
So you addressed the oil pump, o-ring, cam retainer plate. Did you hook up a mechanical gauge to confirm the oil pressure? If so, sounds like its going to be terrible.
Old Aug 17, 2008 | 07:14 PM
  #88
Thats the last thing I can do. Mechanical gauge.
Old Aug 17, 2008 | 08:58 PM
  #89
NavyBlue99SS's Avatar
I hate to tell you this but thats the FIRST thing you should have done. If the guage reads zero like you say it has then you would have some serious knocking and tapping going on. You would have heard the rods knocking and the lifters tapping due to no oil but you claim the engine sounds fine. This leads me to believe that you have a problem with the sending unit or a short some place causing incorrect values to be sent to the guage.
GET THAT MECHANICAL GUAGE HOOKED UP ASAP!
Good luck man I hope it turns out well for you!
Old Aug 18, 2008 | 10:11 AM
  #90
I really thought it was a mechanical problem. But I have a gauge now. Just waiting for the adapters.
I am going to have to remove the blower belt to be able to hear the engine better.
Thanks.
Old Aug 18, 2008 | 10:58 AM
  #91
Thanks.
I got my fingers crossed for you bro!
Old Aug 18, 2008 | 11:22 AM
  #92
chpmnsws6's Avatar
That is the first thing that should be done when diagnosing a low oil pressure problem. Verify with a mechanical gauge...... It might save you and your engine builder tons of grief
Old Aug 18, 2008 | 11:59 AM
  #93
P Mack's Avatar
When you had the pan off how closely did you look at the oil pickup tube? Are you absolutely sure there's nothing blocking the flow in the tube or the screen on the end?
Old Aug 18, 2008 | 12:29 PM
  #94
I pulled it completely off. The screen was completely clogged. I cleaned it all out and blew air through it.
Old Aug 22, 2008 | 07:32 PM
  #95
Mechanical gauge verifies the low pressure. Guess it's internal. :rant:
Old Sep 20, 2009 | 12:53 PM
  #96
Default A Year Later
To close this out, it ended up being a cam bearing.
According to the new engine builder. It moved 1/4 in.
I am up and running again with a new rebuilt engine.
Old Sep 20, 2009 | 01:44 PM
  #97
hammertime's Avatar
indeed
Glad to hear you have resolved the issue.
Old Sep 21, 2009 | 01:59 PM
  #98
STAR's Avatar
Were they stock bearings or aftermarket? How does a cam bearing end up moving?
