Thought it was a colapsing lifter???
Old Apr 5, 2003 | 11:49 PM
BYBYC5's Avatar
*Bad Trader*
Default Re: Thought it was a colapsing lifter???
TTT i have this noise tooo. my started after i replaced a broken valve spring...
Old Apr 6, 2003 | 11:45 AM
Johns98Z28's Avatar
Sorry I didn't post this earlier.....
The noise ended up being a wrist pin. All of my bearings were fine when I pulled the motor. So I replaced all the bearings, rings, and put Wiseco forged pistons in while it was apart. She runs like a scalded ape now.....well compared to some, she runs like a pussycat...compared to others, she runs like a scalded ape <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
Old Apr 6, 2003 | 04:56 PM
LS1derfull's Avatar
A wrist pin is the link between piston and connecting rod. It seems a little odd that your noise came and went if it was a pin.Also since pin is pressed in rod, than wear must have been in piston pin bore since aluminum is softer than steel pin.
Old Apr 6, 2003 | 07:47 PM
vette's Avatar
If you spun a rod bearing wouldn't it cut off the oil to that rod journal? If it does this it will not run very long at all. It will go to pieces.
Old Apr 7, 2003 | 12:50 AM
BLUEBYU's Avatar
Help me out...what is a wrist pin? Where is it located?
