any problems with bent pushrods in ls1's or trucks
Old May 9, 2003 | 11:07 PM
Cody Brooks's Avatar
Default any problems with bent pushrods in ls1's or trucks
i was in the dealership service department working with my assigned mechanic ( i'm doin apprenticeship type training).when a 2002 z71 came in that wouldn't start. well we switched the fuel pump, 4 fuel injectors, and spark plugs because water or something had gotten into the fuel and ruined those. it ran after that but we heard a sound and relized it was a bent pushrod pulled out the pushrod and it was in a "s" shape. i'm wondering if anyone else has had that happen. it happened with a completely stock valvetrain.
Old May 10, 2003 | 12:49 AM
Krazy98Z28's Avatar
Default Re: any problems with bent pushrods in ls1's or trucks
the factory pushrods are junk. usually a over rev like missing a gear bends them
Old May 10, 2003 | 03:17 AM
Jabroni's Avatar
Yes, not uncommon at all. A friend had a pushrod shaped like an "S" when we swapped his cam, most likely caused by a mechanical overrev. The rev limiter wont help you there.
Old May 10, 2003 | 12:02 PM
Y2k Pewter TA's Avatar
Yeah that is avery comoon problem with all the LS1's so even when u get on it the 1st time and rev up 2 5500 rpm guess what u hv just bent a pushrod even the 1st time u do it now it might not bust ur engine but they r slightly bent now.
Old May 10, 2003 | 05:05 PM
MyLS1Hauls's Avatar
You dont bend pushrods at that low of an rpm. It only happens when you mechanically over-rev the engine, usually by missing a shift and spinning the motor to 7000 rpm. Stock pushrods are not junk...they are not at fault...its driver error plain and simple. They bend because the valve smacks a piston and then trys to slam shut and transferring that energy through the rocker arm to the PR. I raced the hell out of my motor when it was stock and pushrods came out straight as an arrow. On a rare occasion, you may end up with a weak valvespring, which floats a valve, but thats pretty rare.
