Cam TR224
What's your car running in the quarter mile w/o nitrous? I guess your still running the 228 cam (i kept one of your earlier posts).
Yes, my current car has the 228/230.
Do you have and sound clips of your 225 cam? I was looking into that cam but it seems like not too many people use it.
hands full of guys have gone 11's cam only
114 lsa is usually preferred for A4 guys
2000 Camaro SS 6-speed
TR224 112 lsa
stock untouch 853 heads
free mods
slp lid / slp bellow / paper filter / LS1 Intake Manifold
Pacesetter painted/rusted LT's / H-pipe / dynotech bullets w. dumps
weld in Subframes / LCA's / LCA relo brackets / Adj PHB / Adj Tq Arm
Moser 12 bolt > 4.10's
Centerforce dual friction clutch
MT ET Streets (bias ply - not a radial) on 16" t/a wheels - stock 10 spokes in the front
battery relocated to trunk
some typical weight reduction - !ac/!back seat/!sound deadening/!pass seat
STOCK pulley / water pump / throttle body etc etc etc
car only put down 373hp / 355tq
dyno numbers dont mean ****... but track times do
11.60
119 mph
1.59 60'
FWIW, the overlap on the 225 cam is the same as my current 228/230 114, so, they should lope about the same.
The idle clip in your sig is the idle i'm looking for but i'm in CA so i need my cam to a little smaller than yours
(now whos the comedian, huh?)
the freeze plug is creating a leak on my v-tech adaptor, which is putting extra load on my motor (approximately 28 hp).
