pulled out head need suggestion
Old Jul 6, 2007 | 07:22 PM
forcedIS's Avatar
Default pulled out head need suggestion
sup guys,
I did a leak down test, 2 cylinders were 70 percent (LS1 01 Camaro).
The leak was coming from the exhaust valves on those 2 cylinders.
Squirted some oil on the 2 cylinders it remained 70%.
So I pulled the head out and this is what the pistons look like.
Carbon build-up see Pix.
My question is do I need new pistons or not?
I took pictures of the worse ones?
My plans are building the motor around 450whp/450 wtq.
I am doing a lot of search on head and camshaft package, hopefully
I can acheive the amount of power that I am looking for.
Thanks in advance.
Attached Thumbnails pulled out head need suggestion-dsc02788.jpg   pulled out head need suggestion-dsc02787.jpg   pulled out head need suggestion-dsc02786.jpg   pulled out head need suggestion-dsc02785.jpg
Old Jul 6, 2007 | 10:25 PM
forcedIS's Avatar
ok let me rephrase this, can I just clean the piston(build-up).
What do you use?How?
Old Jul 7, 2007 | 02:15 AM
PREDATOR-Z's Avatar
Brake cleaner, plastic ice scapper, rags and elbow grease.
Have to bring every piston to TDC
Old Jul 7, 2007 | 03:20 AM
bsf's Avatar
bsf
Permatex Gasket Remover works better than anything else I tried. It literally causes the carbon build-up to slough off.
Old Jul 7, 2007 | 09:14 AM
Zitty'sZ's Avatar
I just finished cleaning my pistons and I used WD-40 and fine scotch brite... they cleaned up like new and it was not very hard to do.
Old Jul 7, 2007 | 09:54 AM
Pharcyde50's Avatar
You do not want to use scotchbrite it contains AL oxide the dust from the scotch brite pads can cause premature wear to your bearings and other areas of the motor! Another vote here for permatex gasket remover.
Old Jul 7, 2007 | 04:09 PM
forcedIS's Avatar
Thanks alot guys.
Looking at the pictures is the build-up bad?
But anyway, I have to clean it for now, Kinda tight on budget.
Again Thanks a lot.
By the way anybody wants to help, I got that new bud light (blue).
I'll take care of your air fare to Honolulu Hehehehehe.
