Which lifters?
Old Jul 7, 2007 | 02:36 PM
99TransAmLS16Spd's Avatar
Default Which lifters?
I need some help. I currently have the MS4 cam installed. I just bought the PRC stage 1 LS6 heads. I am definetely going to change out the stock lifters, but I'm not sure which ones to go with. I am on a budget, so needless to say the less $$ the better. I've been looking at the comp magnum "R" lifters, but will these work with the stock rockers or would I be forced to go with an aftermarket adjustable set? Would the Comp High Energy lifters be ok, or will that limit my redline? Thank you for any input.
Old Jul 7, 2007 | 03:38 PM
99blancoSS's Avatar
GM him perf lifters from SDPC.
Old Jul 8, 2007 | 12:52 PM
Are those the LS7 lifters? Part #12499225 for $100 at sdpc. After doing extensive research, I think the LS7 lifters will be fine for my application-I will be spinning to 6,800 once I change the rod bolts.
Old Jul 8, 2007 | 01:18 PM
Camaro01SS4life's Avatar
Caddy lifters...Great lifter for a good price...
Kev
