LM7 max lift?
Old Jul 7, 2007 | 06:33 PM
Sled's Avatar
Default LM7 max lift?
Anyone know what LM7 valve springs can handle stock? I'd like to put in a stock LS6 camshaft before I drop the 5.3L in, but worried about valve springs, and possibly valve-piston clearance.
I don't really want to pull the heads and change springs at this moment. Plan to pull it out in the next year and either build a new motor based on a 6.0L block or fully do up the 5.3L into a 5.7L and so on. Just figure for now, if I can find a used cam cheap, why not?
Old Jul 7, 2007 | 07:44 PM
DONAIMIAN's Avatar
I would upgrade to the LS6 springs. You dont have to pull the heads for a spring swap.
