93,000 miles?
Old Jul 8, 2007 | 04:33 PM
00ssSLP's Avatar
Default 93,000 miles?
I was wondering what everyone thought about putting a cam in a LS1 that has 93,000 miles on it? I don't want anything big, maybe just a cheater cam or somthing close to it. I have heard stories of people putting in a cam at high miles and the oil pressure going low and wipping out cam bearings. I would also like to know whatelse do I need besides a cam to make this work?
Old Jul 8, 2007 | 06:49 PM
melchoir's Avatar
Refer to the sticky.
You will need:
Pushrods
Valve Springs
Cam
Crank Pulley bolt
Timing cover seal/front seal
If a 98 model, water pump gaskets
Recommended
- New oil pump
- O-ring for oil pump pickup tube
- Timing chain
Even with all that I'm probably forgetting something off of the top of my head.
Old Jul 8, 2007 | 08:41 PM
will69camaro's Avatar
Sex On Wheels
I just did heads/cam, i have 100 miles on the setup and it just rolled 95k miles, i did ALL new gaskets...Basically everything but bearings and rings were replaced...Runs well so far (~knocks on wood~)
William
Old Jul 8, 2007 | 09:46 PM
hugger1975's Avatar
You will need:
Pushrods
Valve Springs
Cam
Crank Pulley bolt
Recommended
- New oil pump
- Timing chain
What he said.
I am at almost 100k now.
Started with about 95k
No issues yet.
Exactly what he said
