oh my god! FINALLY!!
Old Jul 11, 2007 | 07:22 PM
  #41
5_02ls1's Avatar
i was mislead by the title of this thread. this has absolutely nothing to do with Tainted losing his virginity
lol......that's a good one....lol...a lil cruel but funny......
Old Jul 11, 2007 | 11:18 PM
  #42
bww3588's Avatar
ill be standing there pointing and laughing when this motor pops........
Old Jul 11, 2007 | 11:21 PM
  #43
Tainted's Avatar
no you wont, cuz you just remember, you donate $$ and that will be money lost for us both
LS2=chain **** compared to my double roller
Old Jul 11, 2007 | 11:55 PM
  #44
bww3588's Avatar
wrong, the money i donated was to get you a hair cut.....i can see it was a waste already.
Old Jul 12, 2007 | 09:52 AM
  #45
crainholio's Avatar
It ain't gonna run long enough to pop...
My bet's on either he chews up the crank trying to monkey the balancer on w/ a bolt, or he'll actually get it started and it'll just fill the crankcase up w/ bearing shavings and lock up.
Then will follow the inevitable "ZOMG whys my engin not start???????????????"
Old Jul 12, 2007 | 12:24 PM
  #46
Tainted's Avatar
crainholio do you have nothing better to do than plan out what might go wrong with this new motor? You havnt had a single good thing to say as far as I can remember, so could you please just shut the **** up?
Old Jul 12, 2007 | 01:13 PM
  #47
crainholio's Avatar
Admit it, you crave attention. It's like oxygen to you. Soak up the bad with the good, or stop post-whoring.
Since I'm typing anyway, here's something helpful:
If you check the alignment between your crank and cam timing gears using a steel straight-edge, you'll probably find they're a smidge out of line. Easy mistake for a competent engine builder to make, which means in your case it's a sure thing.
If you didn't clean and Loctite the cam gear bolts, now is a great time to go back and re-do them. You'll be fixing the gear alignment on the crank gear end anyway.
Aligning the front & rear main oil seals without the J-tools is tough. The front can be done using the balancer and a good eye, the rear is not likely to happen. If your granddad just slaps on the seal carriers like he did on older SBCs it is a guaranteed leaker.
I still think that poor engine's fate was sealed the minute the heads went on, but what the hey.
Old Jul 12, 2007 | 01:22 PM
  #48
WS6NIGHTMARE's Avatar
Man your thick...he bought the long block, all he put on it was the heads. Lay off the kid already.
Old Jul 12, 2007 | 03:54 PM
  #49
crainholio's Avatar
There's no disputing my thickness, so you're right on that point.
The failure mode you called me out on will happen because he'll fudge up the oil pump and/or pickup and/or pan installation.
And as for you...no heads kinda means it was a short block, no?
Old Jul 12, 2007 | 04:42 PM
  #50
Specialized's Avatar
Old Jul 12, 2007 | 06:27 PM
  #51
Tainted's Avatar
the heads came with the motor but were sent to ARE to be inspected. so it was a lnogblock, but not re-assembled. as far as lining it up, I'll get some help. Everyone here seems to think I can't do a damn thing right, but I assure you I can. I amynot be a master engine builder, but I can do it, the same way you may not be able to do **** as far as body work but I can do things all day with it.
as far as the attention ***** thing, do I like *SOME* attention, sure. but yall keep on and on antagonizing me and when I say something back you say im an attention *****. so really, **** off. if you dont have anymore good input, dont post in my thead.
Old Jul 12, 2007 | 06:35 PM
  #52
ChocoTaco369's Avatar
Tech Resident
actually, that's me.
Old Jul 12, 2007 | 07:20 PM
  #53
LS1NUT26's Avatar
Man I think that I sense a little tension here, well good for you man and I hope you don't F-up your engine.
Old Jul 12, 2007 | 07:22 PM
  #54
Tainted's Avatar
Its jsut getting old that people constantly rag on me for something.
anywho minor update: rear cover is ON, front gasket came in today so I'll be buying a longer bolt to seat the pulley.
Old Jul 12, 2007 | 07:47 PM
  #55
1BadAction's Avatar
aww come on taint, we just funnin ya. u know everyone loves ya taint.
Old Jul 12, 2007 | 10:59 PM
  #56
Tainted's Avatar
see thats fine. but the way he does it isnt. hes doing it to be an assclown and not in a sarastic way
Old Jul 14, 2007 | 04:01 PM
  #57
crainholio's Avatar
(redacted...this guy clearly lacks the mental wattage to process it)
Old Jul 16, 2007 | 12:31 AM
  #58
Shallow Bay's Avatar
WHAT?!?!?! I thought that area was called the gooch.
Old Jul 16, 2007 | 12:34 AM
  #59
Tainted's Avatar
gooch taint chode
